AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
IRSHEET in MAP 3D 2015
1 REPLY 1
Michiel.Valcke
454 Views, 1 Reply
I just discovered that the command _IRSHEET is not available in Autocad MAP 3D 2015.
Is the default command for rubbersheeting now _ADERSHEET or is there another command?
Thank you all very much for your time.
1 REPLY 1
This is not a command of Map3D, never was it.
The command _IRSHEET is a command from RasterDesign, so either you don't have RasterDesign installed or it is not active in your current AutoCAD profile.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
AutoCAD Beta
