WMS connection and zoom scales
Hello!
I'm connecting my Autocad Map 3D 2011 to a WMS and that works great. However, when I set zoom scales on the layers it starts to act wierd. See attached screenshots.
I have sett the top layer called "Bostäder" to view from 0 to 5000. The layer is on top in the draw order list. When I zoom out above 5000 the layer is hidden but it seems the layer is placed on top of everthing else making it invisible. If I uncheck the layer everything the other layers are visible again. See img1, img2 and img3 in sequence to fully understand the issue.
My question is, am I doing something wrong or is this a WMS or Autocad 2011 issue?
Did you ever get an answer to this? I am having the same issue. Scale changes when I print. Alomost like the WMS request specifies a different scale when it is made.
