AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Insert SHP as blocks and use Object Data as block attributes
3 REPLIES 3
DawnAW
1813 Views, 3 Replies
Good Afternoon,
I need help please.  I have been searching the discussion groups and knowledge base and I can't seem to find what I am looking for.  I have a SHP file that I am inserting into a DWG.  This SHP file is made up of points that represent manholes.  I want to bring these in as blocks and have the information in the object data table be automatically placed in the coordinating block attributes, as this information must be available to users in standard AutoCAD.  I am under the impression it is possible but I must be missing something.  Here is what I have done:
-I have created a block that has attribute tags that are named the same as the fields in the object data table.  This is saved in my desired DWG.
-I have used the MAPIMPORT command and selected the SHP file.
-In the dialog box that appears, under POINTS, I select the block I created.  Under DATA, I select Create Object Data. And click OK.
-This creates all my points as blocks and includes the object data but does not place any of the information in my Block Attributes.
-Opening this DWG file in standard AutoCAD eliminates any object data.
I have read that there are ways to annotate these blocks with text, but I am trying to comply with our clients standards which require blocks with attributes that can be seen in standard AutoCAD.
Does anyone know of a way I can do this?  Please keep in mind that I am a novice at AutoCAD MAP.  The version I am using is MAP 2014
Thank you
3 REPLIES 3
DawnAW
in reply to: DawnAW
I think I may have figured this one out.  In the MAPINSERT dialog box > Points > Point Mapping, there is a box to check to "Get attribute values from fields".  Once I checked that box, the attributes are now being populated by the Object Data information.
Thank you.
Murph_Map
in reply to: DawnAW
Thank you.
That's the ticket. You could also used the mapanno blocks to label the manholes then do a save as AutoCAD DWG format.
Murph
Supporting the troops daily.
DawnAW
in reply to: Murph_Map
Thanks for the reply.  I will give that a try too.
