AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Importing Shape files
9 REPLIES 9
Message 1 of 10
888 Views, 9 Replies
When I opened a shape file the drawings are garbled. See picture. It opens fine in QGIS and ArchGIS.
9 REPLIES 9
Message 2 of 10
antoniovinci
antoniovinci
Please zip & upload here that shapefile, sir.
Message 3 of 10
Pointdump
Pointdump
Troy,
Welcome to the Autodesk Forums!
As @antoniovinci says, it would be helpful for diagnoses to post your shapefile.
I remember, in my dim memory, seeing this once before, but I can't recall specifics. In the absense of data to test, the only thing I can offer is to suggest turning off High Quality Geometry to see if it's a graphics issue:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Troy,
Dave
Dave Stoll
Las Vegas, Nevada
Message 4 of 10
Gary_Braun
Gary_Braun
I've seen similar issues at times when Map has had to reproject the data; if they have different coordinate systems assigned then run a test making sure that your shp file and dwg are both using exactly the same coordinate system and see if it looks any better.
Message 5 of 10
scheel
in reply to: Gary_Braun
scheel
the best way to verify this is to didn't assign a coordinate System to a new drawing.
In this case Map will use the coordinates as it and will assign the original coordinate System of the shp file to the drawing if known.
Using this way we can see if the Problems depends of coordinate System Transformation.
Thorsten
Thorsten Scheel
Contelos GmbH
Thorsten
Thorsten Scheel
Contelos GmbH
Message 6 of 10
in reply to: antoniovinci
Sorry for the late reply. Been busy with some other things. Attached is one
of the files. I hope this helps.
Troy
Troy
Message 7 of 10
in reply to: Pointdump
Hello Dave,
Thanks for the response. I already emailed @antoniovinci one of the shape
files.
Where can I find the setting for High Quality Geometry?
Troy
Hello Dave,
files.
Troy
Message 8 of 10
Pointdump
Pointdump
Troy,
I don't see your attachment.
As for the High Quality Geometry setting, Type GRAPHICSCONFIG in the command line or Right-Click here:
Dave
Dave Stoll
Las Vegas, Nevada
Troy,
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 10
Thanks. That solved the problem! What I did was to turn off the hardware acceleration option because the high quality geometry option was disabled (dimmed). I think my video card is not compatible.
Message 10 of 10
antoniovinci
antoniovinci
I didn't get anything, sir, but glad you figured out how!
