AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import TAB files in Map 3D 2016
2 REPLIES 2
461 Views, 2 Replies
Good day!
Faced with the following problem:
When I import TAB files with command Import Maps layers of geometric objects are inserted correctly with the preservation of all sizes, scales, etc., but the text placed in one point. More precisely not in one point, and scales. I tried and export in MapInfo directly into DWG, the same situation. See the pictures:
1. Text approaching
2. Location text objects
3. Same in MapInfo
Maybe anyone knows a solution to this problem?
2 REPLIES 2
gluckett
Perhaps there is no coordinate system set in the Text export?
Can you share the TAB?
in reply to: gluckett
Good day, gluckett!
Yes, the reason in this. The solution here .
Thanks!
Technology Administrators
