AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
exporting to DXF
5 REPLIES 5
605 Views, 5 Replies
exporting to DXF
I've been trying to export a file to DXF, but  when I open it on another computer,  it will only show those objects drawn in the file and none of the data points or polygons I connected through .SHP files. Is there a way to get these features and their data to show up in an .XDF
5 REPLIES 5
rkmcswain
What entity type are the objects that do not show up?
Use the LIST command in the original drawing to find out, and post back.
R.K. McSwain     | CADpanacea | on twitter
Alfred.NESWADBA
if you need geometry as AutoCAD objects (and so to open/view them on other systems using the DXF format) you have to import the SHP geometry using command _MAPIMPORT instead of just referencing them (using command _MAPCONNECT).
Another option could be, to keep all stylizations for the SHP(s) is to run command _MAPEXPORTCURRENTMAPTODWG (>>>details<<<) as first step to convert the FDO stylizations to plain AutoCAD geometry objects and then open this DWG and save it as DXF.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
perfect. thanks. Anyone know why the feature properties, like the names for all my polygons, don't cross over to the conversion?
rkmcswain
Probably because DWG and/or DXF do not support such property.
Alfred.NESWADBA
I have a bit a different explanation: because these objects are only referenced and not really part of the drawing.
It's like an XRef: within the DXF you only have the information "at this position/rotation/scale show the dwg-file xy", but you don't get the objects/the content from file xy into the DXF of your current drawing. FDO-objects are also referenced and not part of your drawing, same with images (not OLE objects).
- alfred -
Alfred NESWADBA
Technology Administrators
AutoCAD Beta
