Import Shape file and separate data into layers based on att
Fleww
Message 1 of 9
Fleww
forum autocad.pngHi, I need this all layers on left side to get in autocad as separated, please can you help me to do this?
Attachment layer name is bf_kronshagen
When I do mapimport I only got 1 layer:/ I want it all with same names. Please help 🙏
Replies (8)
Message 2 of 9
Fleww
I need this one too for layer ef_kronshagen. I need this so hard.:/
Message 3 of 9
Pointdump
Hi @Fleww,
In the MAPIMPORT dialogue box under "Drawing Layer" you can choose to "Use data field for layer name:"
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 9
Fleww
Thank you, I know this, but I cant find all layers there, I was testing it and I can't get it that clean like in QGIS when i open that shape file. Im sending you in pm this shape file.
I need this really but I don't know how to get it ALL, i got like 60%. 😕 I just want that layers on left side showed in QGIS like on picture nothing more.
Message 5 of 9
Pointdump
@Fleww,
Looks like Discussion Admin moved your post to the Map3D Forum.
Zip together your Shapefile data. This Forum will accept up to file size 71MB.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 9
Fleww
Can I insert 2 data field at once? couse 2 columns are different and we need to stack it in same layer by that 2 columns...
Message 7 of 9
Pointdump
@Fleww,
Please zip together and post your data.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 9
ChicagoLooper
This is your site, correct?
To separate by layers, you can follow this example::
  1. I have a shapefile named Trans_RoadSegment_NTDNOFS. I want to separate by street name. The street name attribute is FULL_STREE. See image-1.
  2.  In the Drawing Layer column of the MAPIMPORT command, click the ellipsis (button with three dots). Check Use data field for layer name then select FULL_STREE from the dropdown menu. Click OK twice. See image-2.
  3.  The street line work from the shapefile is imported. The streets are listed by their name in the Layers Properties Manager and each indidvual street is on its own individual layer. See image-3.
Image-1Image-1
Image-2Image-2
Image-3Image-3
Chicagolooper
Message 9 of 9
Fleww
Yea thank you guys I got it, that layers just was empty and I got scared but everything is ok, but this is very useful anyway!! ❤️
