Image Insertion - Drawing Units - Precision
apweng
apweng
Hi there,
Does anybody know if AutoCAD Drawing Units - Precision value affects image insertion?
Thanks!
Andrew
Pointdump
Hi Andrew,
I thought this an interesting question, so I grabbed some Vermont imagery and used MAPIINSERT to import into 2 different drawings, one with precision 0 and one with precision 0.00000000. I got no difference in imagery corners.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ChicagoLooper
@apweng
No, the precision does not affect image insertion.
More important than the ‘precision’ is the native coordinate system of the image. When your image was initially created, the author gave it a projection. Examples include WGS84 Mercator EPSG 3857 (meters), LL83 EPSG 4269 (degrees),  and State Plane Zones NAD83 (feet).
When you assign a coordinate system to your modelspace, your drawing becomes a flat representation of Planet Earth complete with an invisible equator and north pole. When you add a geospatial image to your drawing, the program will do three things: (a) scale the image so it has the right size, (b) rotate the image it has the right north orientation, and (c) move it so it lands in the correct spot.
Understanding the native CS of the image is frequently misunderstood when inserting an image. An image’s native CS must always be honored, not overlooked. Never ever.
Example: An image with native coordinate system using Degrees can be inserted into a drawing with an assigned coordinate system that uses Feet. AutoCAD will perform a transformation to make the image insert accurately. Letting the program perform this transformation is far more critical than precision of drawing units.
Chicagolooper
apweng
Thanks both of you for your replies.  I didn't think so either but I had to clients ask the same question and wanted to dig a bit deeper.
I appreciate your responses.
