I have the following layers in AutoCAD Map 3D 2015:
Layer 1: Shapefile (FDO) with object label (color red) (polygon shapefile)
Layer 2: Industry Model (topobase) label (color blue)
If I make layer 2 visible then the labels of layer 1 are no longer displayed.
The text of layer 1 and 2 overlap.
Is there an option to force AutoCAD Map to draw labels of layer 1 even if they overlap with labels of layer 2?
Screenshot of Layer 1 (FDO Shapefile Object Label in red color):
The "FDO Shapefile Object Label in red" is no longer displayed when Layer 2 (Industry Model Label - topobase) is shown (in blue color):
Hi Jens,
you cannot enable this in Map GUI. Do this:
- save layer as XML (context menu)
- open in editor
- search for your label definition in XML
- below the label definition there should be those tow lines:
<CheckExclusionRegion>false</CheckExclusionRegion>
<AddToExclusionRegion>false</AddToExclusionRegion>
Change from true to false.
- add layer to drawing again
I don't know if you need to change both or not - too lazy to look it up or test.
Rob
Robert, thank you very much. This was exactly the solution.
I used
in the Shapefile (FDO) layer.
Jens
