AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How to force AutoCAD Map 3D to draw a FDO label even if they overlap?
2 REPLIES 2
swt-gis
774 Views, 2 Replies
I have the following layers in AutoCAD Map 3D 2015:
Layer 1: Shapefile (FDO) with object label (color red) (polygon shapefile)
Layer 2: Industry Model (topobase) label (color blue)
If I make layer 2 visible then the labels of layer 1 are no longer displayed.
The text of layer 1 and 2 overlap.
Is there an option to force AutoCAD Map to draw labels of layer 1 even if they overlap with labels of layer 2?
Screenshot of Layer 1 (FDO Shapefile Object Label in red color):
The "FDO Shapefile Object Label in red" is no longer displayed when Layer 2 (Industry Model Label - topobase) is shown (in blue color):
2 REPLIES 2
in reply to: swt-gis
Hi Jens,
you cannot enable this in Map GUI. Do this:
- save layer as XML (context menu)
- open in editor
- search for your label definition in XML
- below the label definition there should be those tow lines:
<CheckExclusionRegion>false</CheckExclusionRegion>
<AddToExclusionRegion>false</AddToExclusionRegion>
Change from true to false.
- add layer to drawing again
I don't know if you need to change both or not - too lazy to look it up or test.
Rob
swt-gis
Robert, thank you very much. This was exactly the solution.
I used
in the Shapefile (FDO) layer.
Jens
