How to Create a PDF for a Layout in Map 3D
I can't seam to figure out how to create a PDF, Map 3D - 2020, from my layout.  The Export to PDF keeps failing. This is to share with others that don't have AutoCAD to view the DWG files.
braudpat
Hello
But why you are not plotting / printing to PDF (Driver : AutoCAD PDF - High Quality Print) the current layout !?
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
I tried, Plot setup doesn't have that as an option. Could my options be set to allow that plot?
pendean
Community Legend
Community Legend
@Anonymous PLOT command while your Layout is on screen in AutoCAD does not have what option exactly?
Or are you that new to AutoCAD/MAP and you need help covering all the basics of plotting? Please explain and be honest, we all have had to learn somewhere and somehow.
I appreciate the help, here are a few screen shots. Maybe I am missing something.
ChicagoLooper
OPTION 1:
Image-1.Image-1.
OPTION 2:
Image-2.Image-2.
Chicagolooper
Thanks, I figured out option #1.  I am learning everyday, Map 3D. Its not my normal work program. Thanks for you help.
