This is a drawing of tunnel. I want to make this 3D tunnel drawing in to 2D as like the attached photos.
Solved by Valentin-WSP. Go to Solution.
If I understand you correctly, you are looking to create cross-sections / section views of this tunnel.
Then consider using Civil 3D, Revit, or Infraworks.
Check their forums: Civil 3D forum, Revit forum, or Infraworks forum
(VIDEO) Instructional Demo:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Yes, I need to create the cross section. So in AutoCAD MAP 3D there is option to create like this. Thank you for your support.
