Grips bug with Map 3D 2018
thierry_prince
Message 1 of 64
thierry_prince
With AutoCAD Map 3D 2018 FR, a new bug has appears. It concern the grips use with several objects.
I post you a video to show the bug with an arc, but there is also some (different) problems with polylines (context menu does not appears after the first change), multi-lines, splines, and perhaps some other objects.
This problem does'nt exist with Map 3D 2017 FR and also not with AutoCAD 2018 FR.
I don't know if other language versions of Map 3D 2018 have the default.
I hope it will be solved ASAP.
Cheers.
Thierry
Replies (63)
Message 21 of 64
albionpjl
Jestes
Check your GRIPOBJLIMIT. If it's a small number, set it to about 32,000.
It may help.
See this thread https://forums.autodesk.com/t5/autocad-forum/stretch-vertex-vertices-grips-missing/td-p/6781070
Message 22 of 64
Nice suggestion, but it has no effect on the bug.
Message 23 of 64
albionpjl
I was replying to jestes who had just described another grips bug. I had both bugs but the variable change that I posted solved the one that matched what he described.
The add vertex etc bug is not solved by that.
Message 24 of 64
This issue is also occurring in custom point objects (see attached image)
Has there been any movement on a resolve yet?
Message 25 of 64
Just ran into this same issue with a client. They are having this issue yet I am not, even when working on the exact same file. After several troubleshooting ideas, the only difference I see is the install method we used. They did the Download Now option from their Subscription site and I chose the Browser Download option. We are going to uninstall C3D 2018 and try the install from the Browser Download next week. Will let you guys know the results.
Message 26 of 64
I used the Brewer download, still have the issue.
You have something different with your PC then what we have, could be a number of items that make the difference.
Just how you decide to download the same file from the same servers will not change the issues we are seeing.
More then likely it has something to do with a version of Window's "insert filename here" and something with the new Autodesk product are not playing well together.
Autodesk needs to fix this, I am sure that they are a where of it by now.
Message 27 of 64
jporter
Yes, Autodesk is aware of the issue.  On page 1 of this thread  @Thomas_Stuehle replied to the post.  It has been escalated to the programming department.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 28 of 64
Has there been a hot fix for this bug yet?
Message 29 of 64
Message 30 of 64
Thomas_Stuehle
Good news - I would like to forward the hotfix for the described issue.
It is attached at the article "Grip issue with editing polylines and arcs in Map and Civil 2018" in the Autodesk Knowledge Network.
Please mark the comment as a solution if it solved the issue  also on your side.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
Message 31 of 64
kboldt
Thank you Thank you Thank you!
Message 32 of 64
Thank You! Works perfectly.
Message 33 of 64
Just a question, is anyone else (after installing fix) seen some strange things with the program? Such as grips taking longer to respond to a command; waiting on the program to just respond to a command, etc.
I work on extremely large grading files and you know windows is always making updates so this is most likely just my PC, but I thought that I would ask if anyone else is seeing some strange things after the update.
Message 34 of 64
Alfred.NESWADBA
selection of objects with many vertices is always a bit slower if the property window shows all properties.
E.g. for a polyline the property window shows length and area, both values which can need a lot of time if you select polyline(s) with large number of vertices.
You can speed up that selection if
  • you close the property window and only open it if you need it
  • you keep the property window open, but close some groups in the property window ... for properties which need long time for calculation. For a polyline you can minimize the group "Geometry"
...and ... the next selection is faster than before 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 35 of 64
Thank you for that tip it is a very good tip to know, however I already knew about that setting and it is not what I am asking in my original post.
I asked if anyone else is seeing "Strange" or "Slower" responses from the program after the install of the "Fix", it is more then likely a windows issue on my PC then it is the program itself; I would just like to be sure that is all.
But good of you to post that helpful hint, I am sure someone will learn something from it, its just not what I am talking about is all, sorry.
Message 36 of 64
Alfred.NESWADBA
Short answer: no, I have not seen any differences to before installing the hotfix.
- alfred -
Alfred NESWADBA
Message 37 of 64
I am getting slower response in general while working when the "Show annotation objects" is turned on. I don't know how to turn it off by default, so turning it off manually for each drawing. It does affect my workflow, and speed up things. My PC is an i7-4790K, 16 gigs of RAM, 850Pro SSD, but not a GPU (only integrated one), maybe a GPU would benefit overall responsiveness.
Message 38 of 64
Thanks a bunch! It's been a headache since moving to Map 2018.
Message 39 of 64
Any update on this issue? Having these issues as well.
Message 40 of 64
jporter
@Anonymous, did the solution that @Thomas_Stuehle provide (message 30 above) not work for you?
Jason Porter
www.asti.com
