Just to let you know I am a complete novice to AutoCAD Map 3D.
I've created a contour layer from an ASC file (UK Environment Agency Lidar), these are polylines and I can see from their feature properties that they have elevation values.
Is there a way I can export these contours to AutoCAD, Revit and/or sketchup. Whenever I export or save as a DWG or DXF the contours are all coming out with a Z value of 0.
Do i somehow need to trabslate the elevation properties to a Z value?
Many thanks!
If you already have the polylines in your drawing with the elevation properties, one way to generate polylines with the the corrected z value is to use a query which is shown here: https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Alternatively, and potentially more simply, you could create a new surface and Add a DEM File and set the Files of Type to *.asc.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCADĀ® Civil 3DĀ®
