Error Message - define industry model layers
Morning, Started a drawing from Electric NA template. Data Connected to tax lots and road names. Placed transformers in the drawing using Electric Ribbon Device, did a Save as, when bringing up the saved file and go to add the transformers to the container, I get an error message "
Command:
ELADDFROMMAP
Please define industry model layers in the map first.
Feature Container [All/Segment/Duct/Conductor/dEvices/sTructures/cIrcuit] <All>: A
Command: *Cancel*
Any ideas on what to do?
I am new to Map so I am unsure of what it wants me to do, I have tried going on the TASK PANE/Display Manager/ right click on Electric North America and update. which has no effect. Also refreshing the layer TRANSFORMER has no effect.
Any help will be appreciated.
Have a Great Day! B"H
Hi @Anonymous,
In the Autodesk AutoCAD Map 3D 2​016 Readme, the answer is provided for the issue you are running into.  With Industry Model drawings, when a crash or some other unclean close has occurred the next time the Industry Model drawing is opened, all layers will incorrectly be displayed as read-only.  This may result in temporary files not being deleted from a temporary folder upon exiting the AutoCAD Map 3D application.
Solution:
  1. Start the “Run…” dialog and enter “%temp%” and click OK
  2. Locate the folder named “Embedded”. (This folder can contain n-1 sub folders where temporary file(s) are stored.)
  3. Remove all files and sub folders under the “Embedded” folder.
After the temporary folder is cleaned out, you can open the Industry Model drawing again to continue working.
Best regards,
Deron
Deron Smith
scheel
maybe I think too simple. Do you have tried to generate the standrad display model first?
Do you see any fdo-layers inside teh working area?
No electrical-command will work without generating a displaymodel first.
Once assigned it will generate the assigned displaymodell automatic when opened the next time.
When you see fdo-layers, then check the otheer tip you recieved before me.
Thorsten
Thorsten Scheel
Contelos GmbH
thanks for your suggestions...I ended up shutting down the computer as just closing AutoCAD did not help. When everything started AutoCAD recognized the file as it should have.
do not know what causes it as it happens quite a lot.
Regards
Linda
