Error: Failed to get bands data
kscolfer
Message 1 of 19
kscolfer
Platform: AutoCAD Map 2014 64bit
I downloaded jp2 aerial photo from "The National Map".  The image is a NAIP aerial.  When I connect to it as a FDO Raster Image, it comes into the map in the wrong area (as in many miles off).  My map is set up on Colorado State Plane Coordinates (CO83-NF).  The metadata says that the aerial is UTM NAD 83, but it comes in as unknown datum.  So I edit the FDO coordinate system to UTM NAD 83 Zone 13N, meters (UTM83-13); zone 13 should be correct for this area.
Any ideas why this won't work?  I've done this dozens, if not hundreds of times in the past with all the previous formats that NAIP aerials came in and it worked well.  No luck with these jp2 photos though.
Help please?
Replies (18)
Message 2 of 19
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
Maybe you could try to install the SP 2 for MAP 2014 !?
http://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/autodesk-autoc...
Have you done some successful tests with an other ACAD MAP or with QGIS or other GIS software ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 19
antoniovinci
Please copy and paste here the link to that .JP2 imagery, thx.
Message 4 of 19
kscolfer
Antonio, Thanks for the reply.  Here is a link to one of the two photos with which I am having trouble: Click here to download
I appreciate your help!
Kelly
Message 5 of 19
kscolfer
Braudpat,
Thanks for the reply. Yes, good idea. I did install SP2 and still get the same result. Have not tried other ACAD MAP, and do not have access to other GIS software.
Message 6 of 19
diane.cloutier
Hi Kelly,
I downloaded the .jp2 file from the link you provided and added it to a new Map 3D 2014 drawing with no coordinate system assigned to the map or data.  The coodinates of the lower left corner of the image are about -11,897,254, 4,920,576.
I tested in in QGIS and got the same results.  The negative value of the X coordinate leads me to believe that the image is not georeferenced correctly, and therefore a data issue (rather than a software issue).  Can someone else confirm this?
Thanks!
Diane Cloutier
Message 7 of 19
kscolfer
That's interesting, and I'm really curious about other's opinions as well.  All of the various aerial photo formats produced by NAIP have worked well with ACAD Map, in the many years I've been using it (I think since 2005).  I've tried 3 or 4 of these JP2 formatted aerials, and none have worked.  I don't know what that means, but FYI.
Message 8 of 19
diane.cloutier
Hi Kelly,
Can you provide a full link to where you are getting this data that you are having the issue with (rather than to a single file download)?  Can you also provide a link to where you have downloaded the other photos that have worked for you in the past?
Thanks!
Diane Cloutier
Message 9 of 19
kscolfer
Hi Diane,
Here is the link to "The National Map Viewer" http://viewer.nationalmap.gov/viewer/
This is the same place I have been grabbing aerial photo images for years, however they migrated from tif to jp2 evidently in early 2013. I can't get you a tif from them because they are not offered any longer. However, I did start looking back at previous mapping efforts, and the jp2 images were working for me in 2013, just not recently this year. Like I said, I have recently tried 4 different jp2 images and none worked, so I don't know what's going on. I really appreciate your efforts to help me figure it out. Thank you.
P.S. All the other geo-reference data that I work with on a regular basis works just fine, including other aerial photograph formats, so it really is just these jp2 images that have recently been causing the headache.  I don't think its a global GIS problem with my installation.
Message 10 of 19
parkr4st
where is the image located?  Lat long or another reference, twom county, etc.
dave
Message 11 of 19
antoniovinci
Hi Kelly, your Jpeg2000 refers to Steamboat Springs (CO), isn't it..?
Please check if my attachment (monochromatic for bandwidth reasons) fits exactly to your UTM map, thx.
http://dropcanvas.com/lbisj
Message 12 of 19
kscolfer
Antonio, I think perhaps you figured something out. That image you sent does fit exactly into my map. I'm waiting anxiously to find out what it is that you figured out!
Kelly
Message 13 of 19
antoniovinci
Well, those "strange" coordinates are typical of EPSG:3857 reference system.
If you set it in your J2K imagery, you'd better convert it to a "human" CRS, e.g. EPSG:26913 as I did.
Message 14 of 19
kscolfer
Antonio,
Thanks for the response.  I've been out of the office for a few days.  I had to do a little research to figure out what an EPSG:XXXX CRS is.  Not terminology I am familiar with, but then, I'm no geographer.  I think it is the same as NAD 83 UTM Zone 13N, correct?  I thought that is what I did when I assigned UTM83-13 in the "edit spatial contexts" dialog box (see attachment) while bringing the map in as a FDO Raster.  AutoCAD did not recognize the NAIP photo's CRS and listed it as unknown, so I edited it in that manner, with it still showing up in the wrong place.  Obviously, you got it to show up in the correct space so you did something I didn't.  I just can't figure out how you did it.  Can you provide a step-by-step instruction, as its not working for me when I edit the CRS in the manner which I usually do.
Thanks for the help!
Kelly
Message 15 of 19
antoniovinci
Unfortunately my old release does not support FDO, so you outta wait for someone's else help, sir.
Anyway, did you try my previous advice, i.e. set the EPSG:3857 upon opening your .JP2 file..?
Message 16 of 19
parkr4st
Kelly
Here's a link to look at to see what crs tnm has available
http://www.usgs.gov/faq/categories/9854/3731
What types of projections are supported by TNM services?
In addition to the WGS84 Web Mercator Auxiliary Sphere projection (EPSG:102100), TNM Services support commonly used spatial coordinate reference systems, such as CRS: 84 and EPSG: 3785, 3857, 4267, 4269, 4326, 54004, 54008, 102113, and 900913. TNM Services also support Alaska and North Pole projections/coordinate systems, such as EPSG: 3338, 3571, 3572, 3573, 3574, 3575, 3576, 7250, 102016, and 102017.
UTM83-13N  is EPSG 32613,
http://reference.mapinfo.com/common/docs/mapxtend-dev-web-none-eng/miaware/doc/guide/xmlapi/coordsys... has a list of utm wgs 84 EPSG codes
It has several maps. look at the third one down.  Antonio thinks worldwide in terms of this type of grid which is why he is so good at placing items
use 3857 and the image is postioned correctly.  we just have to belive that.
dave
Message 17 of 19
kscolfer
Dave and Antonio,
Thanks to both of you for the help. You'll have to forgive my ignorance, but I had never even heard of EPSG before this discussion, since most mapping products I've been exposed to reference the description (i.e. UTM NAD83 Zone 13) rather than EPSG code, even though I now realize each CRS can be referenced by both. I am educated more now than before, thanks to you both. Using EPSG 3857 did in fact place the aerial in the right place. I just can't figure out why it works, since the metadata for those photos states that the horizontal datum is NAD83 (aka EPSG:26913, since the geographic area is Zone 13N), which didn't work. How did you guys know, and how was I supposed to know, that the metadata is misleading and the correct CRS to use is EPSG:3857 (WGS84-based Mercator[spherical projection])?
Just to be clear, my map is in Colorado State Plane CRS (CO83-NF, or EPSG:231),  and I set EPSG:3857 as the "native" CRS used for the photo when setting it as a FDO.  That is how the aerial is now correctly referenced in my drawing.
Thanks to you both!
Message 18 of 19
antoniovinci
kscolfer wrote:
How did you guys know?
Dave's already answered in his last post: "We just have to belive that".
For him it's a matter of faith, and for me... it's only italian "sixth sense", sir.
Message 19 of 19
kscolfer
Antonio,
Thanks, I've only been using AutoCAD for occasional GIS the past 10 or so years (occasional means 5-20 maps per year). I'm a biologist, not a cartographer. I learn new stuff every year. I gotta say, the "we just have to believe that" answer drives me nuts, but that is the way it seems to be in the AutoCAD GIS world. I truly appreciate your help, and envy your Italian 6th sense. Now I just gotta remember this, as my Irish American memory allows me to forget everything but my grudges!
Take care,
Kelly
