- Mute
- Permalink
- Report
Platform: AutoCAD Map 2014 64bit
I downloaded jp2 aerial photo from "The National Map". The image is a NAIP aerial. When I connect to it as a FDO Raster Image, it comes into the map in the wrong area (as in many miles off). My map is set up on Colorado State Plane Coordinates (CO83-NF). The metadata says that the aerial is UTM NAD 83, but it comes in as unknown datum. So I edit the FDO coordinate system to UTM NAD 83 Zone 13N, meters (UTM83-13); zone 13 should be correct for this area.
Any ideas why this won't work? I've done this dozens, if not hundreds of times in the past with all the previous formats that NAIP aerials came in and it worked well. No luck with these jp2 photos though.
Help please?
