I added orthophotos to a Map 3D 2025.0.1 drawing via "Data Connect->Add Raster Image or Surface Connection", then XREF'd a drawing containing topography lines.
Plots via "Output->Export->PDF" and "SSM->Publish->Publish to PDF" both show just the orthophotos and no topography.
The attachment shows snips from the layout and from the PDF.
The orthophotos are about 300 MB and the topo is about 50 MB.
I've tried:
- Draw Order->Bring to Front
- Draw Order->Bring Above Objects
- binding the XREF (bind, not insert)
- hardware accel on / off
- DirectX 11 / 12
- 2D Display Settings->Basic / Intermediate / Advanced
- REA
Other info:
DRAWORDERCTL = 3
NVIDIA RTX A1000 Laptop GPU w/ driver 561.03, DCH, Direct3d level 12_1...
DedicatedSystemMemory 0
DedicatedVideoMemory 4,157,603,840
SharedSystemMemory: 17,007,407,104
PNPDeviceID VEN_10DE&DEV_25B9&SUBSYS_B1A1028&REV_A1&LUID_0\16422&FLAGS_0
DiscreteAdapter True
DoublePrecision Supported
RayTracing Supported
