DRAW ORDER NOT HONORED DURING PLOT
dave_evans46Q8H
dave_evans46Q8H
I added orthophotos to a Map 3D 2025.0.1 drawing via "Data Connect->Add Raster Image or Surface Connection", then XREF'd a drawing containing topography lines.
Plots via "Output->Export->PDF" and "SSM->Publish->Publish to PDF" both show just the orthophotos and no topography.
The attachment shows snips from the layout and from the PDF.
The orthophotos are about 300 MB and the topo is about 50 MB.
I've tried:
  • Draw Order->Bring to Front
  • Draw Order->Bring Above Objects
  • binding the XREF (bind, not insert)
  • hardware accel on / off
  • DirectX 11 / 12
  • 2D Display Settings->Basic / Intermediate / Advanced
  • REA
Other info:
DRAWORDERCTL = 3
NVIDIA RTX A1000 Laptop GPU w/ driver 561.03, DCH, Direct3d level 12_1...
DedicatedSystemMemory 0
DedicatedVideoMemory 4,157,603,840
SharedSystemMemory: 17,007,407,104
PNPDeviceID VEN_10DE&DEV_25B9&SUBSYS_B1A1028&REV_A1&LUID_0\16422&FLAGS_0
DiscreteAdapter True
DoublePrecision Supported
RayTracing Supported
O_Eckmann
In Map workspace palette you could try to add the layer in which you have inserted your XREF and put it above your FDO raster
Olivier Eckmann
ChicagoLooper
@dave_evans46Q8H
When you add your XREF, what layer does it land on? Can you upload an image of the Layer Properties Manager that shows the Xref's hosting layer?
Chicagolooper
dave_evans46Q8H
Thank you for the idea.  Since I'd already "bound" the XREF, I couldn't do exactly what you suggested.  But your suggestion did make me notice that the "task pane" has a "Draw Order" tab (which I'd been oblivious to until then), and I used that tab to switch the position of the "Map Base" and the raster group.  That worked!  Odd that the standard "select entity->(rt clk)->Draw Order->etc." approach didn't/doesn't work.  Thank very much!
dave_evans46Q8H
Thank you for the reply.  Since I'd already "bound" the XREF, I couldn't do that.  But the comment by @O_Eckmann led me to a solution that works.
