AutoCAD Map 2023 - MAPIMPORT Command crash
Y.AUBRY
Advisor Advisor
Message 1 of 11
Y.AUBRY
Since last week, I have had an AutoCAD Map 3D crash when launching the MAPIMPORT command (see video below).
I checked, my AutoCADs are up to date, no Windows updates pending, I cleaned the old paths in the registry, I reset the AutoCAD settings to default but still the same.
The -MAPIMPORT command works well when FILEDIA is at 0.
Do you have a suggestion?
https://go.screenpal.com/watch/cTVQohnepr8
Thanks, Yoan
Yoan AUBRY
Replies (10)
Message 2 of 11
ChicagoLooper
Hi @Y.AUBRY
OK, thanks. Your uploaded image, program updates, FILEDIA status is all good but still need more info. What format are you trying to import? Vector or raster? And what format? Shp? Kml/kmz? Jpg? Tif? Sid? DEM?
Different file types may use different import procedures. Did you download the data? Can you share the link? Even better, can you share the actual file?
Chicagolooper
Message 3 of 11
Y.AUBRY
Hy @ChicagoLooper,
I'm trying to import shapefiles.
But the problem is not the format, the problem is the graphic interface.
Autocad crash before i can see it.
I send you shp files as exemple
Yoan AUBRY
Message 4 of 11
ChicagoLooper
Hi @Y.AUBRY
Bannalec, correct?
Go to Command line, Enter MENULOAD. Do you see Planning and Analysis in the list under Loaded Customization Groups?
Chicagolooper
Message 5 of 11
Y.AUBRY
Hi, yes, got it
For information:
- I've tried to unload all my custom UI
- I've tried restore my default settings
A+ Yoan
Yoan AUBRY
Message 6 of 11
Y.AUBRY
I have done a copy of ManagedMapApi.dll and I have trying to understand where the code is crashing without results
I have clean all the folders in the %AppData%\Roaming\Autodesk\AutoCAD\Recent
Yoan AUBRY
Message 7 of 11
O_Eckmann
Have you tried to clear MapCache folder ? C:\ProgramData\Autodesk\Autodesk AutoCAD Map 3D 2023\R24.2\MapCache
You could also try to made a research in windows registry of key MapImportDialog  and clear or change value to see/view another folder when using MAPIMPORT
Olivier Eckmann
Message 8 of 11
ChicagoLooper
@Y.AUBRY
Unload the Map3D Ribbon then reload the M3D Ribbon.
  1. MENULOAD
  2. Planning & Analysis=>Unload
  3. Browse to Support Folder=>Select Map_Planning & Analysis
  4. Load=>Close
Chicagolooper
Message 9 of 11
Y.AUBRY
After clearing MapCache & MapImportDialog in REGEDIT, reloading the M3D Ribbon Map_PlanningAnalysis.cuix & 2dDrafting.cuix, AutoCAD is still crashing.
A+ Yoan
Yoan AUBRY
Message 10 of 11
braudpat
Hello @Y.AUBRY
A priori, je pense que OUI car sinon le -MAPIMPORT aurait aussi des problemes !?
Voir le fichier joint provenant de MAP 2022 ... Sait on jamais !
Ton fichier "MapImport.ini" est il correct ?
Et je rajoute par securite, les autres fichiers INI ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 11 of 11
Y.AUBRY
Salut @braudpat ,
Je viens de tester mais toujours pas malheureusement.
Merci tout de même.
A+ Yoan
Yoan AUBRY
