AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
DIsplay Vertices
10 REPLIES 10
Message 1 of 11
MihaiAnghius
10461 Views, 10 Replies
DIsplay Vertices
Is there any way ohtar than selection or a custom aplication to display the vertices of a line,polyline or 3dpolyline ? ( AutoCAD Map3D 2014)
10 REPLIES 10
Message 2 of 11
welcome @Anonymous.autodesk.com!
>> is there any way ohtar than selection or a custom aplication to display the vertices
AFAIK: No direct way.
Can you describe whatfor you need that, maybe that brings up some ideas.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
braudpat
in reply to: MihaiAnghius
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
Sometimes I have to "mark" 2D/3D Pline vertex (control point), so (since 2008) I use a Lisp routine called : NOD-PL
which draws a graphic point at each vertex (control point) of a 2D/3D Pline (Splined or Not)
Maybe NOD-PL could help you !?
Regards, Patrice (I am not an Autodesk/AutoCAD Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 11
I needed to draw multiple polylines on specific vetices that were close together on a long polyline, got the job done by using a linetype with a large scale so it wouldn't display it on the closer vetices.
Message 5 of 11
You can change the property "Linetype Generation" of a polyline, that handles the linetype distances and vertices in another way.
In case of "Disabled" you will see every vertex (as long as it's not 180°), in case of "Enabled" the corners/vertizes might not be "visual painted".
Disadvantage with setting "Disabled" ... when the vertices are closer than the distance of the linetype-gap then the poly looks like a "continuous" one.
- alfred -
Alfred NESWADBA
Message 6 of 11
This is the drawing and the linetype i used if you're curious
Message 7 of 11
H
Message 8 of 11
halo all goedmorning
Tags (1)
Message 9 of 11
in reply to: braudpat
Are you able to vary the size of the graphic point? And how do you remove the points afterwards?
Message 10 of 11
Alfred.NESWADBA
Can you please explain what you mean by "graphic point"?
- alfred -
Alfred NESWADBA
Message 11 of 11
shonemml
Tnx for sharing lisp! Great, this is just what i need!
Technology Administrators
AutoCAD Beta
