- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any way ohtar than selection or a custom aplication to display the vertices of a line,polyline or 3dpolyline ? ( AutoCAD Map3D 2014)
welcome @Anonymous.autodesk.com!
>> is there any way ohtar than selection or a custom aplication to display the vertices
AFAIK: No direct way.
Can you describe whatfor you need that, maybe that brings up some ideas.
- alfred -
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
Sometimes I have to "mark" 2D/3D Pline vertex (control point), so (since 2008) I use a Lisp routine called : NOD-PL
which draws a graphic point at each vertex (control point) of a 2D/3D Pline (Splined or Not)
Maybe NOD-PL could help you !?
Regards, Patrice (I am not an Autodesk/AutoCAD Advisor)
Patrice BRAUD
I needed to draw multiple polylines on specific vetices that were close together on a long polyline, got the job done by using a linetype with a large scale so it wouldn't display it on the closer vetices.
You can change the property "Linetype Generation" of a polyline, that handles the linetype distances and vertices in another way.
In case of "Disabled" you will see every vertex (as long as it's not 180°), in case of "Enabled" the corners/vertizes might not be "visual painted".
Disadvantage with setting "Disabled" ... when the vertices are closer than the distance of the linetype-gap then the poly looks like a "continuous" one.
- alfred -
This is the drawing and the linetype i used if you're curious
halo all goedmorning
Are you able to vary the size of the graphic point? And how do you remove the points afterwards?
Can you please explain what you mean by "graphic point"?
- alfred -
Tnx for sharing lisp! Great, this is just what i need!
