Disable Auto-Look at text when typing?
billydunbar2000
758件の閲覧回数
6件の返信
メッセージ1/7
billydunbar2000
Is there any way autocad will let me type into an MTEXT box without snapping my camera to it? A large part of my workflow is typing callouts for construction to follow into a layout page that also includes a viewport. The text boxes are in a different part of the page from the viewport and in order to type the callouts I need to look at the viewport to see what I'm describing. The problem is that autocad snaps the camera to the text box if it isn't in your view when you're typing, so I can't type and zoom into what I need to see at the same time.
0 件のいいね
解決済み
759件の閲覧回数
6件の返信
返信 (6)
メッセージ2/7
ChicagoLooper
Hi @billydunbar2000
Sorry, but your explanation is vague. Please explain to clear up the confusion.
  1. Are you placing your mtext on paperspace (on a layout tab) or in modelspace?
  2. Does your field of vision automatically zoom-in to your cursor when entering your mtext?
  3. Do you want to be zoomed-out when entering mtext such that you have a wide field of vision?
Chicagolooper
0 件のいいね
メッセージ3/7
billydunbar2000
I hope this clarifies my issue
1. Paperspace, but this behavior is conserved through all of autocad
2. The field of vision automatically zooms to fit the mtext box when entering text
3. I want to be zoomed in to a part of the page that does not contain my mtext box. Currently if i want to see the viewport while typing, I must zoom out see both my text and the viewport.
0 件のいいね
メッセージ4/7
ChicagoLooper
Are you using an old version of AutoCad?
What is your MTEXTFIXED value?
Have you tried changing the value?
Chicagolooper
0 件のいいね
メッセージ5/7
billydunbar2000
This value is new to me, so thanks for sharing it. Sadly, it doesn't help me here. It does not allow me to type in an mtext that isn't in my view. Also I am using the 2020 version of AutoCAD Map 3D
0 件のいいね
メッセージ6/7
Pointdump
解決済み
Hi William,
Use Notepad++ to type your callouts, then Copy/Paste into MTEXT.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
0 件のいいね
メッセージ7/7
billydunbar2000
yeah that makes a lot of sense. i've opened the print up in trueview to be able to do both before, but i havent considered just typing it somewhere else first. thanks for the tip
0 件のいいね
