Data table: "Zoom to objects" with which zoom-size?
Peter2_1
Peter2_1
When I'm clicking through the "data table" with enabled option "zoom to selected object", I have different results: (see attachments)
- for "pipes" (line element), the zoom factor is "fit entire object to screen": That makes sense ..
- for "armature" (point object), the zoom factor is "fit object to a part of the screen". Fine, I can see the object and the environment
- for "fountain", the zoom factor is "fit entire object to screen". That's nonsense, because I see a huge black spot on my screen and nothing else.
Can this zoom factor be influenced in some way?
AutoCAD Map 3D 2023 German / Oracle
pendean
Community Legend
Community Legend
Those are hard coded and you have no access to control them in the program sadly: give Autodesk feedback here about it all https://www.autodesk.com/company/contact-us/product-feedback
Peter2_1
@pendean
thanks for advice.
ChicagoLooper
There's a subtle, very subtle, relationship between the Auto-Zoom button and the individual rows in the table. A Blue Outline surrounding the Auto-Zoom button is either toggled ON or toggled OFF (see image-1).
1-Auto-Zoom button does not have a blue outline.1-Auto-Zoom button does not have a blue outline.
While in your table view, you can click directly on top of the 'Auto-Zoom' button. When you do, a Blue Outline surrounding the button will appear. Click it again and the outline toggles OFF. When the outline is ON, you will zoom-in on the entity provided you click inside the extreme left column (see image-2). When you are zoomed out, and the outline is toogled OFF, you will highlight the entity without zooming in.
2-Auto-Zoom button displays a blue outline so the zoom-in feature is ON.2-Auto-Zoom button displays a blue outline so the zoom-in feature is ON.
Chicagolooper
Peter2_1
@ChicagoLooper
thanks, that's a very precise description of this feature.
But I think that is exactly what I've done, and at the moment I don't see how it explains the different zoom factor I showed in my images.
