- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I using using the mapexport function to export the data from AutoCad MAP 3d 2024 to KML or MIF file. When I check the coordinates in the Autocad MAP 3d the coordinates are OK but if I do export and then import KML into Google Earth the location is displaced.
I am using the coordinate system Hong Kong Grid 1980 in AutoCad MAP 3d and for export I convert coordinates to LL84. The drawing is Hong Kong (AUtoCAD MAP 3D) but in the Google Earth is placed somewhere in Thailand. If I check the coordinates in the exported *.kml file they are wrong.
I have already followed the instructions on this page: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/KML-file-is-shown-...
This instructions didn't helped. Any other idea what could be wrong ?
Thank you!
