Data Check: SQL 'ORDER by' does not work
Peter2_1
Message 1 of 1
Peter2_1
In Infrastructure Admin I added some self-defined "Data checking" statements and used also the SQL-statement "order by"
I t works fine and well-sorted in
- SQL-Assistant
- SQL-developper and
- with "Syntax is correct" in SQL-Check.
But the data-check started from
- Map 3D gives me fine results, but unsorted.
- and IM Data Editor gives me same results, but in another way unsorted than Map.
Is there a way to get sorted results?
AutoCAD Map 3D 2023 German / Oracle
Replies (0)
