CREATING MULTIPLE POLYGON BOUNDARY
shil143
Message 1 of 9
shil143
Please help to create multiple boundary for between polylines...
Replies (8)
Message 2 of 9
АлексЮстасу
Do you need polylines to have different Elevations? Look at the left or the like.
In my opinion, the General scheme is as follows:
1. Drawing Cleanup (MAPCLEAN):
Converting Lines, Arcs, 3DPolylines to regular Polylines can also be done in MAPCLEAN:
Sometimes MAPCLEAN needs to be run multiple times. Sometimes with different actions. It depends on the source data.
And better control in Interactive mode.
The tolerance depends on the accuracy required.
2. Create an areal topological model - MAPTOPOCREATE.
3. If it is necessary to unload from this model areas (closed polylines, in groups - if polygons are complex) - MAPCLPLINE.
This sometimes requires painstaking work and attention. Sometimes not everything is clear when managing topological models. But it works, and precise areal objects are obtained.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 3 of 9
Koesti
Autodesk Support
Autodesk Support
Hi @АлексЮстасу ,
one additional command which might close the loop: _MapTopologyToPolygons
Create closed Polylines from Topology objects.
Regards
Brigitte Koesterke
Technical Support Senior Specialist
Message 4 of 9
parkr4st
Mapexport to a sdf file selecting polygons and select all the line work.
The attached file is the result with elevations to zero.
everything else needs drafting corrections.  there are over lapping area, unclosed intersections, other drafting errors.
Message 5 of 9
parkr4st
sdf attached
Message 6 of 9
АлексЮстасу
Hi, Brigitte,
Yes, this is the MAPCLPLINE command - my item 3.
Message 7 of 9
Koesti
Autodesk Support
Autodesk Support
Hi @АлексЮстасу,
yes, the result of both is the same 🙂 and sorry not realizing the second command.
Regards
Brigitte Koesterke
Message 8 of 9
АлексЮстасу
Message 9 of 9
АлексЮстасу
 Sorry!
I misunderstood you! I thought your "MapTopologyToPolygons" is the name of the action, not the command.
I did not think that there are two commands that do the same thing - MAPCLPLINE and MAPTOPOLOGYTOPOLYGONS.
Or are these commands somewhat different?
