How to DATA Connect using MySQL
jeguizaASRZM
jeguizaASRZM
Hello, I was wondering if anyone can explain how to use data linking with the "MySQL" connection option.
What type of data does this let me connect? Tables? Pictures? DWGs? I know it says spatial references so how would this also work?
Can anyone explain what this does and what sources would I need to use this option to connect.
Can anyone provide me with a screen cast?
Thank You in Advance!
Alfred.NESWADBA
If you mean command _DBCONNECT then you need to install a ODBC driver for mySQL (like >>>that<<<) (not tried, I'm not using mySQL).
Or, to use Map3D functionality, you could use command _MAPCONNECT and follow >>>that way<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jeguizaASRZM
Thank You for the response!
With the link provided I was able to research more on data transfer with MySQL!
Thank You For The Help
,JE
