Connecting to shape files on one drive with multiple users
ray.harli
ray.harli
Hi All,
I need help with regards to connecting to shp files located on onedrive. We are a small team working on one map which is  not a problem when you have a traditional setup ie a normal mapped network drive
the problem is when I link shp files from my one-drive they have a path that is specific to my computer
such as:
C:\Users\rharl\UrbanSoup Architects\UrbanSoup Architects - 2014\11_2014 Kazerne TOD\04-DATA\4-03-DRAWINGS
When another user opens the same file it looks for the external file using that same path
and obviously it doesn’t work for them and shows a broken link. They then have to manually update the link which is just not practical.
I have tried using a sharepoint url link but Map 3D shp connector doesnt seem to work with a link I created using sharepoint.
Any ideas?
Thomas_Stuehle
Hi @ray.harli
Welcome to the Map 3D forum.
Does it work when you and your colleague redirect your OneDrive folder to another path which also exists on other machines? I found this article which could give a good starting point: "How to Move Your OneDrive Folder".
This way you do not focus on a folder like the one mentioned which only exists on your machine, but e.g. "D:\share\OneDrive"
Did the post help you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
ChicagoLooper
Putting the shapefile in a folder where just one user, that's you, has access e.g. Users\rharl\UrbanSoup Architects\etc...... is not considered a best practice since other users, as you already know, won't be able to connect. You could put your shapefile in a centralized location such as your firm's server. If all users can access this server, for example through a VPN, then your problem is solved. This is guiding principle behind a single shapefile being shared by multiple users: everyone is using the exact same data. This data may be displayed in different ways or analyzed differently by different users, but 'data source' regardless of the user, remains consistent.
Alternatively, all users can put the shapefile on their own local drive just like you, but be forewarned, this is not an ideal solution either, even though it would work. In fact,the same file, copied over from local-drive-to-local-drive is a bad, very bad idea.
Chicagolooper
ray.harli
Hi @ChicagoLooper
I fully understand the principle but the whole reason why we are on OneDrive / SharePoint is precisely to avoid the costly alternatives to having a VPN with a dedicated server etc.
It has become common practice for small businesses to have a NAS drive syncing to OneDrive which is our current setup.
Surely with a massive surge of users shifting to cloud working there must be a solution to this?
