Combining Multiple DWG Files into One
Message 1 of 9
I was wondering if anyone knows a way to combine multiple DWG files into a single file. The reason I ask, is because where I work, we get quarterly data deliveries that map our Town in 70 different files. To be more efficient, I was wondering if there was a quicker way than copying the contents of file "A" and then "pasting to original coordinates" to file "B" 70 different times. If anyone has found a way to copy all DWG and Paste to original coordinates in one shot, it would be greatly appreciated.
Dan
Replies (8)
Message 2 of 9
Alfred.NESWADBA
3 options:
  • command ADEDRAWINGS to connect these mass of dwg-files to your current drawing
  • command ADEQUERY to query data from the external files to your current one ... with possible filtering like some layers, blocks, ...
  • you might also use XRef technology.
Take care to read in the help what exactly happens with that workflow, because you might kill/modify all the external drawings as there exists a write-back functionality for the queried data.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
Thanks so much the XREF worked, however is there a way to paste without making each file its own block?
Dan
Message 4 of 9
Alfred.NESWADBA
Have you tried the other options ...?
- alfred -
Alfred NESWADBA
Message 5 of 9
hi,
there is no command like below
  • command ADEQUERY to query data from the external files to your current one ... with possible filtering like some layers     i Autocad  2016
Message 6 of 9
Alfred.NESWADBA
Then you are not using AutoCAD Map 3D
This here is the Map 3D forum, that's why this suggestion worked well for others.
When you start command _ABOUT, can you show us a screenshot of that dialog?
Also let us know if you are on subscription and so might have access to the toolsets.
- alfred -
Alfred NESWADBA
Message 7 of 9
  1. Thank you Mr. Alfred for reply I didn't see 3DMap forum classification because I search for my point on Google then I see the question and answers ......  I not professional autocad user so sorry for confusion
Message 8 of 9
ktsaleej
My blog shown below link will help you for Insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet
https://ktsaleej.blogspot.com/2017/09/insert-multiple-drawing-files-dwg-or.html
In this link you can generate AutoLISP(.lsp) program to insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet.
Just fill a form and generate your AutoLISP(.lsp) program and run it in your AutoCAD to insert multiple drawing files.
Message 9 of 9
maratovich
This may be useful - Click
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
