Combine queried data into one data table
sam.stibbs
sam.stibbs
I have queried multiple shapefiles based on them falling inside a particular polygon and was wondering if there was a way of then combining all the results into one data table that can then be exported?
Is this possible at all?
parkr4st
saving the queried data to a .sdf file will put all the attributes into on data table
Using MAPGISOVERLAY  Intersection will also produce a .sdf file with the data table for the result of the intersection
selecting the desired parcels and going to the data table and Options  Export  to a .csv file will put the data for the selected parcels in the .csv file
And saving the result to a .layer file will allow placing the data into a map and only the parcels in the selection will be in the data table
dave
