Image pixels are changed when plotting to PDF
I have an low pixel image in AutoCAD (first picture) that changes pixel colours when plotted to PDF (Second picture). It appears the pixels are blended with the surroundings pixels.  I am viewing the image in AutoCAD with IMAGEQUALITY set to Draft Mode.  I have changed the raster DPI settings in Graphics section but this has had no effect.
Any ideas what could be causing this?
Version: AutoCAD® Map 3D 2017
Thanks.
Libbya
Why are you posting this on the Dynamic Blocks forum?
ChicagoLooper
What is your 'plotter setting?' Try changing your Autocad PDF pc.3 to a higher resolution. Note: this will not turn your original low resolution image into a high resolution image. It will merely improve the PDF 'output' during your plot process--you're still using your low res image.
Autocad PDF pc.3 settings.Autocad PDF pc.3 settings.
Chicagolooper
