How do I calculate the area of a shapefile or multiple elements within a shapefile within Map 3D?
open the data table and create a calculation (Options drop down at bottom of table window)
Geometry can be multiplied, divided, etc to give the units needed. Geometry in sq ft Geometry/34560 will yield acres for example
Ooops! Acres is Geometry/43560 not 34560
The other path to travel involves mapimport with data and mapexport with attributes including AREA in the PROPERTIES check-off list to a new .shp . This will place the area in the new data table.
Dave
