Change polylines layer according to its extended options
dani_cs
dani_cs
Hello all
I have a DWG with thousands of polylines. All of them are in the same layer called "us_01usos". Each poyline has extenden options inside: Area, lenght, description etc. The idea is to change each poyline layer according to their "description" field from extended options. These layers are already created with the same name of description field.
I am attaching a very simple example: you will se a huge polyline with a description field "Otros leñosos en secano"
Inside of this, you will see a tiny island with 2 polylines: one is the same "otros leñosos en secano" (because of island boundaries) and other with field "mosaico de cultivo con vegetacion natural". This is a typical example because my dwg has thousands of polylines, most of them inside others. So, there is no problem: each polyline layer to its description field will be awesone.
I am attaching pictures too
Thanks in advance
Accepted solutions (3)
Pointdump
Hi @dani_cs,
Use MAPEXPORT, and retain OD. Then use MAPIMPORT and use Layer Mapping.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
ChicagoLooper
Hi @dani_cs
Try this:
1. Select ALL your polylines then use MAPEXPORT command and export them to shapefile format. Name and save your shapefile in your project folder.
Image-1Image-1
2. The MapExport procedure has three tabs. Make your selections exactly as shown.
Image-2Image-2
3. Open a brand new, clean drawing. Use MAPIMPORT command=>Browse to then select your new shapefile=>OK.
Image-3Image-3
4. In the MapImport window, make your selections as exactly shown.Image-4Image-4
5. Zoom extents to see the polygons. You can change color, linetype, and line weight on a ByLayer basis.
Image-5Image-5
Chicagolooper
O_Eckmann
Hi @dani_cs ,
You can use a request to alter properties OD field as Layer.
(view in My Videos)
Olivier Eckmann
dani_cs
@O_Eckmann @Pointdump @ChicagoLooper
hi all!!
Thanks a lot for your answers!!!! you have saved me lot of hours of working!!!
