AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Grid Precision with MAPLOADGRIDSTYLE command
2 REPLIES 2
Matheus-Lima
190 Views, 2 Replies
Hello, folks!
I have a simple question about grid coordinates and precision settings. The MAPLAYOUTREFERENCESYSTEM command works fine, I set the units with the UNITS command and the grid precision is perfect.
Now following this example: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-edit-the-Re....
I can't set the precision of the grid with the MAPLOADGRIDSTYLE command for some reason, it is always 6 as in this print. Precision in UNITs are set to 3 here.
Does anyone have an idea? What am I missing? Maybe, ambient settings override ? Thanks!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Labels (2)
2 REPLIES 2
Pointdump
in reply to: Matheus-Lima
Hi Matheus,
Good question!
After changing precision in UNITS, I guess you need to re-do command MAPLAYOUTREFERENCESYSTEM.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Matheus-Lima
in reply to: Pointdump
Hi, Dave! Yes, I guess I really need to re-do the command MAPLAYOUTREFERENCESYSTEM to update the precision. I thought that after setting the precision in UNITS you would need just to do a REGEN or something, but apparently no.
Thanks!
Matheus Lima
Technology Administrators
