Cant Log In in ACAD MAP
gmeinero
Message 1 of 12
gmeinero
im pretty sure there's another post with this issue but i couldn't find it.
I cant log in, when i click nothing happens.... already tried renaming or erasing "Web Services" folder any suggestions ?
Replies (11)
Message 2 of 12
rkmcswain
Is this a network license (in which case you do not have to log in)
Or a subscription/rental plan? (in which case, IDK how it's working)
Message 3 of 12
gmeinero
It is a networked license
Message 4 of 12
rkmcswain
Makes sense. Is there some reason you want to log in?
We remove the entire Infocenter.
Message 5 of 12
gmeinero
i want to use geomap service
Message 6 of 12
rkmcswain
You may have told the dialog to not show any more.
Follow the instructions here to make the dialog show again.
Once you have a coordinate zone defined and attempt to turn on the Bing maps/images, it should prompt you to sign in again.
Message 7 of 12
gmeinero
not working. Tried to show every dialog box but not working. I have coordinate zone defined, export to kml is working fine.
Right now Im trying other app like plex-earth 5d 😓
Message 8 of 12
ChicagoLooper
Have you assigned a coordinate system to your drawing? Was it a projected coordinate sys or geographic coordinate sys? Projected CS will give your drawing a basemap such as Bing aerial imagery, a geographic CS won’t.
What CS did you assign? When looking at the image in your original post, it doesn’t indicate a coordinate system has been assigned.
Chicagolooper
Message 9 of 12
gmeinero
Im using projected coordinates, i know the screen capture doesnt have one, but i wanted to show the dialog at the top. thanks
Message 10 of 12
Pointdump
Hi @gmeinero,
Have you tried signing in with Autodesk Desktop App?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 11 of 12
ChicagoLooper
I agree with @Pointdump to sign in using the Desktop app. Just as long as the app has not been uninstalled or is corrupted.
Chicagolooper
Message 12 of 12
gmeinero
thanks that worked, thanks everyone
