Cant Log In in ACAD MAP
gmeinero
gmeinero
im pretty sure there's another post with this issue but i couldn't find it.
I cant log in, when i click nothing happens.... already tried renaming or erasing "Web Services" folder any suggestions ?
Replies (11)
rkmcswain
Is this a network license (in which case you do not have to log in)
Or a subscription/rental plan? (in which case, IDK how it's working)
gmeinero
It is a networked license
rkmcswain
Makes sense. Is there some reason you want to log in?
We remove the entire Infocenter.
gmeinero
i want to use geomap service
rkmcswain
You may have told the dialog to not show any more.
Follow the instructions here to make the dialog show again.
Once you have a coordinate zone defined and attempt to turn on the Bing maps/images, it should prompt you to sign in again.
gmeinero
not working. Tried to show every dialog box but not working. I have coordinate zone defined, export to kml is working fine.
Right now Im trying other app like plex-earth 5d 😓
ChicagoLooper
Have you assigned a coordinate system to your drawing? Was it a projected coordinate sys or geographic coordinate sys? Projected CS will give your drawing a basemap such as Bing aerial imagery, a geographic CS won’t.
What CS did you assign? When looking at the image in your original post, it doesn’t indicate a coordinate system has been assigned.
Chicagolooper
gmeinero
Im using projected coordinates, i know the screen capture doesnt have one, but i wanted to show the dialog at the top. thanks
Pointdump
Hi @gmeinero,
Have you tried signing in with Autodesk Desktop App?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
ChicagoLooper
I agree with @Pointdump to sign in using the Desktop app. Just as long as the app has not been uninstalled or is corrupted.
Chicagolooper
gmeinero
thanks that worked, thanks everyone
