BING Map Images
BING Map Images
landry.tchimou
Message 1 of 8
BING Map Images
landry.tchimou
The load of BING Map Image doesn't work anymore in my AutoCAD Map 3D. It worked after the install during around one month but now nothing. When i execute the command "GEOCARTE" AutoCAD stop working.
Replies (7)
Message 2 of 8
ChicagoLooper
Have you:
  1. Assigned a coordinate system that’s appropriate to your map?
  2. Is your coordinate system a projected CS and not a geographic one?
  3. Are you signed in to your A360  account?
  4. Do you see the Bing logo in the lower right corner of your screen?
Chicagolooper
Message 3 of 8
landry.tchimou
1. I assigne the CS UTM84 30N
2.
3. Yes i'm connected to A360 account.
4. Nothing appearred. When i click to show the image AutoCAD stop working
Message 4 of 8
ChicagoLooper
Can you describe 'AutoCAD stop working?' What does that mean? Does AutoCAD shut down? Does your cursor freeze?
Does the bing logo display in lower right corner or your monitor?Does the bing logo display in lower right corner or your monitor?
Do you see the Bing logo in lower right corner of your monitor?
Chicagolooper
Message 5 of 8
ChicagoLooper
Try this:
  1. Assign UTM84-30N to modelspace.
  2. Go to Geolocation Tab=>Tools Panel=>Mark Position Dropdown=>Select Lat-Long (see image-1)
  3. On command line, for Latitude type in 5.261569 then ENTER. For Longitude type in -3.926760 (this must be negative) then ENTER.
  4. Then, at your 'flashing cursor type 'Aeroport.' When finished typing, move your mouse to LEFT SIDE of Geomarker then left-click.  Hit ENTER.
  5. Type in FIND on command line. Type 'Aeroport' in Find what:'  section. Next, OK, then click magnifying glass icon to zoom-in, then click DONE (see image-2).
  6. Select the Geomarker. In the Properties Palette change the SIZE to 200 (see image-3).
  7. Do not zoom or pan. Turn on Bing Maps.
  8. You may now zoom and pan.
1-Insert a Geomarker.1-Insert a Geomarker.2-Run the FIND command.2-Run the FIND command.3-Increase the size of the Geomarker.3-Increase the size of the Geomarker.
Chicagolooper
Message 6 of 8
landry.tchimou
The cursor freeze and nothing else. When that happens i kill the process and relaunch ACAD.
Message 7 of 8
ChicagoLooper
Message 8 of 8
landry.tchimou
I foung the solution to my problem with the help of Customer Support.
I have just installed the update of AutoCAD (AutoCAD 2018.1.2.).
