autocad map 3d doesn't read .cpg file from shapefile
hrvoje.lovric
hrvoje.lovric
HI,
I have .shp with .cpg file (utf-8), but autocad doesn't read .cpg correctly because it's not displaying characters well in table.
With Qgis I have same problem, but in Qgis I can change from system encoding to use encoding from .cpg file.
How to solve problem in AutoCad?
Alfred.NESWADBA
afaik AutoCAD Map 3D does not eval the CPG-file.
If you can define a setting in QGIS then run a conversion in QGIS to another type of datastore, so hopefully the chars get converted.
You might also try to run command _MAPIMPORT (importing to object-data), are the char's the same wrong ones then?
- alfred -
PS (in case the mod has not already moved the thread): the Map 3D forum is >>>there<<<
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
hrvoje.lovric
Thanks for quick response.
Please mod move this post to Map 3D forum.
I tried to convert in Qgis and with mapimport (OD) but nothing changes.
Still looking for solution.
