AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCad Map 3D 2015 - Problem drawing PL while switching tabs
5 REPLIES 5
453 Views, 5 Replies
Hey!
When I’m with two or more opened dwg files and I’m drawing a PL in one of them, the PL command is automatically shut down when I switch between tabs.
In older versions (Map 14, 13 and 2012) it was possible to switch tabs without shut down the command.
Is it possible to work on AutoCad 2015 the same way? Or is it a bug?
Thank you.
Rafael
5 REPLIES 5
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
Just a quick "stupid" idea : Have you installed the SP 3 on your MAP 2015 ?
http://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/autodesk-autoc...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Alfred.NESWADBA
Because of removed fiber in AutoCAD 2015 this is not possible any more, only one command can be active within an AutoCAD session. Changing from one document to anohter one ends the command.
If that helps: >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
parkr4st
in reply to: Alfred.NESWADBA
open two or three concurrent incidences of AD with a dwg in each.   when you change windows the cursor will pick up where you left off.  Just click on the window header to get the mouse to the window and continue drawing.
dave
in reply to: braudpat
Yep, it was the first thing i've tryed. Doesn't work =/
Thanx anyway!
Thank you Alfred!
Guess i'm gonna back to Map 2014 =S
Technology Administrators
AutoCAD Beta
