AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Area in Autocad Map 3D
9 REPLIES 9
Message 1 of 10
1493 Views, 9 Replies
I have a problem while calculating the area in Autocad. Particularly I draw a polygon and calculate i'ts area. After that I draw the same polygon as polyline and the calculated area was different! How is this possible? Where is the problem?
Thanks a lot
Labels (1)
9 REPLIES 9
Message 2 of 10
pendean
Show us: post your DWG file with the two objects in place as noted above.
Message 3 of 10
ChicagoLooper
Please take screenshot of the first polygon. Include the Properties Palette in the same screenshot. Next, do the  same with the second polygon—take a screenshot with the Properties  Palette. Finally upload both screenshots to the forum.
Chicagolooper
Message 4 of 10
this is the DWG file
Message 5 of 10
in reply to: pendean
Message 6 of 10
braudpat
Hello
Your 2D Pline is BAD ! ... With 3 BAD Vertex : 7 / 8 / 9
Area = 48.81585640 = Length = 35.56267166
au niveau du point X=11.02305141 Y=13.17681706 Z=-1.02000000
au niveau du point X=14.01956049 Y=15.39055099 Z=-1.02000000
au niveau du point X=12.72996930 Y=17.13614095 Z=-1.02000000
au niveau du point X=14.54168511 Y=18.43967568 Z=-1.02000000
au niveau du point X=19.78589581 Y=11.26081797 Z=-1.02000000
au niveau du point X=15.02996920 Y=7.75603034 Z=-1.02000000
Vertex 7 : au niveau du point X=11.02305141 Y=13.17681706 Z=-1.02000000
Vertex 8 : au niveau du point X=14.01956049 Y=15.39055099 Z=-1.02000000
Vertex 9 : au niveau du point X=12.72996930 Y=17.13614095 Z=-1.02000000
Please look at my Blue PLine with ONLY 6 Vertex ! ... The Area is OK ...
So I draw a NEW RIGHT One with the BPOLY Command ... See my DWG ...
THE HEALTH (Stay Safe, Stay Home, Stay Live), Bye, Patrice (The Retired Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 7 of 10
АлексЮстасу
Such polylines can be fixed by _MAPCLEAN (Drawing cleanup):
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 8 of 10
ChicagoLooper
Using your drawing that you uploaded in Post #3 of this thread, the area of both building footprints have the same area. No modifications to either footprint was made. See image below.
Try the hatch method:
  1. Hatch the bulding footprint on the left=>select the hatch and view AREA in the Properties Palette.
  2. Hatch the footprint on the right=>select the hatch and view AREA in the Properties Palette.
Using the hatch method, how do the footprints compare? Is one larger? Which one? Or are they the same?
Please share your method or the formula to calculate the floor area?
Chicagolooper
Message 9 of 10
Yes, you are right! using the hatch method the area of both polygons is calculated the same. How is this possible?
Message 10 of 10
parkr4st
look at your dimensions   right side  fourth decimal place    3 in one 4 in the other  should be a clue.
