AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Are multiple overlapping (p)lines parallel?
2 REPLIES 2
487 Views, 2 Replies
I'm interested if there is a command which can check if multiple overlapping lines are parellel.
I am using AutoCAD Map 3D 2017
Labels (1)
2 REPLIES 2
ChicagoLooper
Sorry, there is no command that can do that.
BTW, many forum users and other semi-important people would like to know why you need to know that?!? Please give a detailed explanation. There might be another way to accomplish your goal WITHOUT using parallel lines.
The only work-a-round would be to perform a fillet with radius=0. If you can fillet then the lines are NOT parallel. If you cannot fillet then the lines are parallel.
<<You cannot fillet parallel lines!>>
Chicagolooper
in reply to: ChicagoLooper
Many of my drawings require overlapping and adjacent rectangles. It often happens when I zoom in real close, lines aren't on top of each other, or appear not to be. Sometimes I can draw pline between two points (which were supposed to be one on top of other) but the length is 0.0000.
I can't figure out how to avoid that problem, especially since I don't have Nearest on Object snap on.
Therefore, I would like to easily check if sides of rectangles are parallel. My current way of doing it is drawing xline and then zooming in and out like a maniac.
Thank you for the answer!
