2018 Define Query SQL inaccessable
dabbott
Observer Observer
dabbott
Observer
Observer
In AutoCAD MAp 3d 2018 on a Windows 10 machine...
I have an .mdb attached.
I can see all the tables listed in the Task Pane.
I have attached a drawing.
When I go to Define Query, I set Location for "All".
I go down to SQL and it doesn't allow input. The buttons are greyed out and you can't type anything in this window.
ChicagoLooper
Take a screenshot of modelspace so it shows all the current AutoCad drawing entities. Then take another screenshot of the Explorer Tab in the Map Task Pane. Please upload both screenshots.
Chicagolooper
dabbott
Observer
Observer
ChicagoLooper
Sorry, I don’t know or work with SQL.
If have an mbd, there are ways to ‘attach’ that mdb to your drawing, such as (1) ODBC using a DSN through your Windows or (2) ODBC by creating a UDL.
You can read about it >>HERE<<.
Chicagolooper
O_Eckmann
is your MDB attached in drawing 037.DWG too? Because uyou can only request object available in drawing sources.
Olivier
Olivier Eckmann
