AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
2017 WMS layer draw order problem
4 REPLIES 4
kajar
1150 Views, 4 Replies
HI!
I have problem with WMS layers using MAP 2017. When drawing have more than one wms layers then its not possbile to view two layers together, only one layer is visible. In map 2016 everything was able to see layers together.
In my case I have two wms layers: top layer, cadastral properties(background is transparent) and second one is ortofoto layer.
Actually property lines must be visible on top of ortofoto.  It seems that developers have messed up WMS functionality in new version of MAP 3d.
So I must use 2016 when I want to use WMS layers, its not normal that newest software is worse than previous.
Does anybody else having problem using WMS using MAP 2017?
I added picture which illuistrates my problem.
Kajar
4 REPLIES 4
Murph_Map
in reply to: kajar
Have you tried to set the draw order in the display manager?
Murph
Supporting the troops daily.
kajar
in reply to: Murph_Map
Of course, I have dried everything.
Finally I have to move back to 2016 when needed to work with  WMS layers
So it seems new M3D 2017 having at least one improvement: downgraded  WMS functionality 🙂
Thomas_Stuehle
in reply to: kajar
Hello @kajar,
please insert 3DCONFIG in your command line and switch the "Hardware Acceleration" off. It worked on my side.(Explanatory screens below).
  • Enter 3DCONFIG in the command line
  • switch the "Hardware Acceleration" off
Please let me know if this solved your issue. If so please dont hesitate to mark this post as solution or let me know if you need any additional help.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
kajar
in reply to: Thomas_Stuehle
Yes, this is working for now.
I hope service back will fix it soon.
Kajar
Technology Administrators
