HI!
I have problem with WMS layers using MAP 2017. When drawing have more than one wms layers then its not possbile to view two layers together, only one layer is visible. In map 2016 everything was able to see layers together.
In my case I have two wms layers: top layer, cadastral properties(background is transparent) and second one is ortofoto layer.
Actually property lines must be visible on top of ortofoto. It seems that developers have messed up WMS functionality in new version of MAP 3d.
So I must use 2016 when I want to use WMS layers, its not normal that newest software is worse than previous.
Does anybody else having problem using WMS using MAP 2017?
I added picture which illuistrates my problem.
Kajar
Solved by Thomas_Stuehle. Go to Solution.
Of course, I have dried everything.
Finally I have to move back to 2016 when needed to work with WMS layers
So it seems new M3D 2017 having at least one improvement: downgraded WMS functionality 🙂
Hello @kajar,
please insert 3DCONFIG in your command line and switch the "Hardware Acceleration" off. It worked on my side.(Explanatory screens below).
Please let me know if this solved your issue. If so please dont hesitate to mark this post as solution or let me know if you need any additional help.
Yes, this is working for now.
I hope service back will fix it soon.
Kajar
