I've created a Sequence (TB_NOMEN_NO).
When a new feature is created, the default setting of the NAME_NUMBER field of the feature is set to pull from the above sequence, but I'd like to create a VB Script button in order to pull the next available value. This button would be used for features that are already digitized.
We are going through an entire re-naming of our system so rather than creating a new feature, I'd like to overwrite the existing NAME_NUMBER field with the next available value from the TB_NOMEN_NO sequence.
Thanks in advance.
Thanks in advance.
some questions. can you provide some test data (start point and explain your expected results)?
is TB_NOMEN_NO a system variable or something else?
if a new feature is created, do you want to check all existing "NAME_NUMBER" fields to find the highest number?
or, check the TB_NOMEN_NO value?
are you editing existing features or adding new, or both?
what is the workflow? where is your planned "VB Script button" going to be? do you have a user form?
Hi @fieldguy, thanks for your response.
To eleborate...
• I am using forms (industry model).
• I created TB_NOMEN_NO as a sequence.
• Currently, when a new feature is created, the NAME_NUMBER field is defaulted to pull the next value available from TB_NOMEN_NO. This is all 'out of the box' capability with Map 3D. This is done from the form designer.
• We will need to edit existing data as well as add new data. Again, when a new feature is created, the NAME_NUMBER field will automatically pull the next available value from TB_NOMEN_NO.
The issue comes with editing existing data. I need to modify the NAME_NUMBER field of the form so that it is the next available number from TB_NOMEN_NO. Since there is already a value in the NAME_NUMBER field, I'd like to program a script button to pull the next available number from TB_NOMEN_NO and place it in the NAME_NUMBER field.
Hopefully that helps..
To eleborate...
i think that existing data has to be modified before new data can be added. that means the program would have to check each "NAME_NUMBER" field to check if the value is in the sequence already. if it is, then the next available TB_NOMEN_NO (NextVal) would be the position of the value in the sequence + 1. if it isn't, then the "NAME_NUMBER" value will be set to the next available TB_NOMEN_NO (the value in the NextVal position).
you might also need a dictionary or datatable that indicates each TB_NOMEN_NO and a boolean whether it is used or not.
i would start by setting NextVal to 1 (the position of the first value in the sequence). i would use another integer (CurrentVal = -1) when checking each existing "NAME_NUMBER" field. if the NAME_NUMBER value is in the sequence (at position CurrentVal), NextVal will be CurrentVal + 1. but, how can you be sure that the value in that position has not been used already?
you mention "out of the box" capability with pulling the next value from TB_NOMEN_NO - i have never seen or used that feature. that's why i ask what "TB_NOMEN_NO" is - is the sequence an array of integers or strings defined in code?
i am willing to investigate this further but not without test data.
I think I will create a video to explain as it's a bit difficult to explain via text.
I'll post up a video shortly.
Hi Thomas,
try this:
dim Val as long
dim SQL as string
SQL = "select MySequence.NEXTVAL from DUAL"
Val = me.ConnectionTools.LngValue(SQL)
Stelli
Hi Thomas,
try this:
dim Val as long
dim SQL as string
Stelli
