Hello, I have a problem with the Save As window. When you call a Save As option from the menu
of AutoCAD not Save As window appears where you can choose the file location, file name and file type you want. It appears first on the command line I choose the file type and then the other options. There is a setting that must be done to autocad for rescue occur if a window choosing from a menu of AutoCAD?
Thank you
