AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Save As window problem
1 REPLY 1
307 Views, 1 Reply
Hello, I have a problem with the Save As window. When you call a Save As option from the menu aa.pngof AutoCAD not Save As window appears where you can choose the file location, file name and file type you want. It appears first on the command line I choose the file type and then the other options. There is a setting that must be done to autocad for rescue occur if a window choosing from a menu of AutoCAD?
Thank you
1 REPLY 1
Alfred.NESWADBA
set sysvar FILEDIA to 1
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Technology Administrators
AutoCAD Beta
