OSGeo FDO SpatialCondition Error
fieldguy
fieldguy
I am trying to replicate the code >>in this post<<
but I am getting an error >>"The property "SHAPE" is not in the reader's selected property set"<<.
I can connect to my shp file and obtain all of the features but I want to filter by a user selected rectangle.
Does anyone have working code for using a polygon as in "OSGeo.FDO.Filter.SpatialCondition("SHAPE", OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Inside, gv)?
There are samples in the DevBlog but those are using "layers" attached to the current map - that's not what I want.
If necessary I can obtain all of the "points" in this case, and determine if the points are within the rectangle, but that is a "worst case" scenario.
fieldguy
I got this to work - "Geometry" was the key word.
string shp = "DefaultFileLocation=path and shp file name";
IConnectionManager icm = OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager();
            OSGeo.FDO.Connections.IConnection ic = icm.CreateConnection("OSGeo.SHP");
            ic.ConnectionString = shp;
            ic.Open();
            OSGeo.FDO.Expression.Identifier id = new OSGeo.FDO.Expression.Identifier("some feature class");
            OSGeo.FDO.Commands.Feature.ISelect sfeat =
                (OSGeo.FDO.Commands.Feature.ISelect)ic.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
            sfeat.FeatureClassName = id;
// lower left
            DirectPositionImpl ll = new DirectPositionImpl();
            ll.X = 348237.0;
            ll.Y = 6139124.0;
// upper right
            DirectPositionImpl ur = new DirectPositionImpl();
            ur.X = 357177.0;
            ur.Y = 6147692.0;
            FgfGeometryFactory fgf = new FgfGeometryFactory();
            IEnvelope env = fgf.CreateEnvelope(ll, ur);
            IGeometry geom = fgf.CreateGeometry(env);
            Byte[] bytearray = fgf.GetFgf(geom);
            OSGeo.FDO.Expression.GeometryValue gv = new OSGeo.FDO.Expression.GeometryValue(bytearray);
            OSGeo.FDO.Filter.Filter newfilter;
            newfilter = new OSGeo.FDO.Filter.SpatialCondition("Geometry", OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Inside, gv);
            sfeat.SetFilter(newfilter.ToString());
            OSGeo.FDO.Commands.Feature.IFeatureReader fr = sfeat.Execute();
            int featcount = 0;
            while (fr.ReadNext())
                featcount++;
