AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
How to rename Object Data?
2 REPLIES 2
АлексЮстасу
664 Views, 2 Replies
АлексЮстасу
How to programmatically rename Object Data?
How to rename manually in ADEDEFDATA I know.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
2 REPLIES 2
zrobert
Hi;
Try out about this algorithm:
1) Get AcMapODTable
2) Get GetTableODRecordIterator for this table
3) Init iterator
4) Get AcMapODTableRecord with iterator
5) Iterate AcMapODTableRecord in loop
5.1) Get AcMapODTableDefinition from table
5.2) Get current AcMapODColumnDefinition with tableDef.GetColumn(colDef, i)
5.3) Check name of current AcMapODColumnDefinition
5.4) If this is your wanted name, rename it with SetName() method.
Hi;
1) Get AcMapODTable
3) Init iterator
АлексЮстасу
Thank you!
In ADN, I was also advised to use the AcMapODContainer :: RenameODTable method - to directly rename Object Data.
Thank you!
